2550 MFWD steering parts/schematics
MJMJ
Trying to find the right parts page for the steering parts on my MFWD 2550. Im sure Im just not seeing it, but I cant find the page that has the parts circled in red in the attached pic. The joint on mine came unthreaded from the cylinder today. It went right back on, but seems loose until its tightened all the way down. Never had it apart before, but I assume thats not right. Thinking the threads are worn and thats why it came apart? The side that came apart didnt have the clamp on it either. Can anyone help point me towards a part number? Never had this much trouble before. Thanks.
Sorry, try this again.
Well that was fast. I looked and looked and couldnt find the right diagram. Can I ask what site you used? I use the JD parts search site, but I just couldnt find it. Thank you.
Forgot to ask, has anyone else had one of these apart? Im trying to determine what it should feel like as the joint is threaded into the cylinder shaft. My biggest worry is that the cylinder shaft also has damaged threads. What Im describing probably doesnt make sense, but it just felt loose even though it threaded all the way. Once all the way on it felt fine.
Well no wonder I couldnt find it. Ive been looking in the steering section. Thank you both.
