Have a '69 syncro 4020 and i think i have a leak in the rockshaft control valve or rockshaft housing. Any ideas where to start? what components in the rockshaft control valve or housing are known to leak? I have read on here some folks take a plug out of the back and can see oil leaking inside when the 3pt is up and down-any ideas what might cause that internal leak-what are common sources of internal leaks?
Also, I need to replace the front pump, what is the best way to take it out, from above or from below?
Thanks
Hb
Thanks
Hb
