John Deere 1010 blow by
Troy78
New User
I have a a JD 1010. It has a steady fog of blow by coming from the vent tube. My question is why after running for several hours does the oil and coolant lever never change? The blow by smells like normal exhaust. I’m new to this and not a mechanic. What is going on with this thing?
(quoted from post at 05:09:04 07/04/20) I have a a JD 1010. It has a steady fog of blow by coming from the vent tube. My question is why after running for several hours does the oil and coolant lever never change? The blow by smells like normal exhaust. I m new to this and not a mechanic. What is going on with this thing?
worn out old machine. my guess, based on the description, would be that it needs new rings and perhaps pistons/liners.
On the off chance that the rings are stuck . Put a 195F thermostat in it . 40wt motor oil and work it for a few hours .
Wont damage anything to try. The stat and oil are fine to continue using .
Keep running it and just make sure that it never leaks coolant into the crankcase .
