tomstractorsandtoys
A friend just got a 4010 that has not been used much for a few years. It started running rough and does not want to start. Drained fuel tank and changed fuel filters. Tractor will not start with the starter. No smoke when cranking and either does not help. Pull it 5 feet and it would start. Pulled the injectors and the injection pump. The pump had a bad head and rotor. Injectors not bad. Got the pump back today and still the same thing. Will not start with the starter and will not smoke any when cranking. Pull it 5 feet and runs great. Ran it for 15 minutes and went to restart and no go. Starter is spinning it over fast enough but still a no go. What are we missing? Tom
