4650 MFD/powershift
dwag
After warmed up hyd filter light on until 1400 Rpm. Changed filters, checked screen, installed lube test gauge(10#/idle, 35# 2000 rpm) cap pump, no drop in lube, then check powershift in all speeds lube remains steady.No diff PTO on/off, MFD capped. Main pump working fine. My next step is to check trans pump & valve? tia john
Guess I need to post after drinking. lol Looking for leak in hyd's to cause filter light to come on.
If all seems right check or change the sending unit for the light,, it could be faulty.
