830 crankshaft seals
looking for some help on finding the correct crank seals for my 59 830. engine oil running in transmission as well as oil leaking on clutch. Would also like to do the flywheel side as well. Any help would be appreciated, I have not taken apart yet as to using the tractor but would like to order in the seals.
The o-ring seal is available from JD. It is part number R353R and takes 2.
The clutch side seals are also available from Deere. It takes 2 also.
The seals cross to SKF 39895.
