Company Logo Shop Now
Re: JD BR Transmission
Mike M
07-01-2020 07:46:26
I don't think you will find anything much on the 4 speed tranny. Probably set up like the 6 speed is. Check the outer most bearing in the reduction cover. Those typically are bad and they control where the input shaft sets. Do you have the top cover off yet ? Check the bearings on the top shaft and also look for rounded off or broken teeth on the gears from shifting on the go. You would want the hi-low gear to engage all the way on to the little teeth if it has an adjustment.
2rich4me63
07-01-2020 09:58:00
 Re: JD BR Transmission in reply to Mike M, 07-01-2020 07:46:26
Thanks for the reply. Had the top off and the teeth look good. Need to get the little gear into the drive gear about 3/16 more. Ill check the outside bearing and go from there.
Copyright © 1997-2020 Yesterday's Tractor Co.
