oil coming out by clutch pully
swindave
help! i have a 1949 model a, when its running oil is getting throw on the front of the tractor,
just small specks, where could it be coming from?
i looked and couldnt see any place,
thanks for your help!
There's a drain passage in this cover that could be plugged up and not letting the oil drain or more than likely the main bearing needs to be readjusted so you don't have so much play with the crank.
Forgot the cover picture.
