I am having a steering issue with my 2940. The steering is harder to turn then normal, I am assuming emergency steering. 3pt, pto, hi/lo, remotes and brakes all function normally.
I will also add that it started making a chattering noise like a hydraulic line vibrating on the right side. Only did it at higher rpm 1500 and above. I changed hyd filter, steering filter, cleaned screen and put in new fluid today. Screen and filter looked ok. The chattering noise is now intermittent, but steering issue still exist. No change with pto on or off and no change in hi or lo.
Any ideas on the issue? Could it be steering motor/valve?
