Company Logo Shop Now
Re: John Deere 3010 Hydraulic De-stroke
Tx Jim
06-24-2020 03:26:09
Adjusting stand-by pressure with or without a hyd control lever activated should be immaterial IE the results for pressure should be the same when gauge is activated
Rick3
06-24-2020 16:16:57
 Re: John Deere 3010 Hydraulic De-stroke in reply to Tx Jim, 06-24-2020 03:26:09
I知 getting zero Psi without the lever activated and only 700 with it activated.
Rick3
06-24-2020 04:01:40
Thanks Tx. Jim! When I plugged in the gauge to the rear remote and started the tractor, there was no pressure until I engaged the lever. Should there be 2250 pressure 100% when tractor is running?
Rick3
07-08-2020 18:02:25
 Re: John Deere 3010 Hydraulic De-stroke in reply to Rick3, 06-24-2020 04:01:40
Follow up... I was back at it over the weekend. Messing with the stroke control adjustment. Got it up to 1500 psi when engaging the lever for the rear remotes where the gauge was plugged in. When disengaged, it went back down to about 700 to 900. I also took the loader loose/ capped the connection and tried it with no noticeable change. I have a destroke screw ordered which is the next move. If that doesn稚 do it, I知 going to replace the stroke control valve. Do you know of any instructions or YouTube videos on how to replace the stroke control valve?
Copyright © 1997-2020 Yesterday's Tractor Co.
