Company Logo Shop Now
Re: Engine problem John deere 40
Mikemul
06-23-2020 21:52:19
Here the working pictures
M-MAN
06-24-2020 03:53:01
 Re: Engine problem John deere 40 in reply to Mikemul, 06-23-2020 21:52:19
From the second picture I can tell the timing is off IF the oil pump is timed correctly. It would be best to use a timing light at full throttle per the instructions from the manual.
With no timing light you have to put the rotor on and turn it to the advanced position and hold it there while you also turn the distributor to where the points have just opened and tighten it down. The point gap must be set correctly first!
mikemul
06-24-2020 07:56:08
 Re: Engine problem John deere 40 in reply to M-MAN, 06-24-2020 03:53:01
I doesn’t understand the text while you doesn’t have a timing light. Put the rotor on where? And what do you mean with advanced position? You mean I set the contact point to the good value and than turn the engine to the spark mark. And than set the ignition to begin opening points ?
M-MAN
06-24-2020 14:13:14
 Re: Engine problem John deere 40 in reply to mikemul, 06-24-2020 07:56:08
Yes - set the contact point to the good value and then turn the engine to the spark mark.
Next put the rotor on top of the distributor shaft where it normally goes. Turn the rotor by hand as far as it will go. It will only turn one way. This is the advanced position. When you let go the advance springs will pull it back to where you started.
Hold the rotor in the advanced position and then set the ignition to begin opening points.
mikemul
06-25-2020 23:31:41
 Re: Engine problem John deere 40 in reply to M-MAN, 06-24-2020 14:13:14
Hi, i have set the ignition with the timing light at full rpm. now its much better at high rpm and no pops more. here is a video. is this how it post to be?
link: https://www.youtube.com/watch?v=X56s1bFY41M
Greetings Mike Mul
M-MAN
06-26-2020 03:22:16
 Re: Engine problem John deere 40 in reply to mikemul, 06-25-2020 23:31:41
Sweet sounding now! Thanks for sharing your success story.
Copyright © 1997-2020 Yesterday's Tractor Co.
