Company Logo Shop Now
Re: John Deere 3010 Hydraulic De-stroke
Rick3
06-23-2020 18:39:56
I envision springs and small parts flying toward my face under that tractor! LOL! What you are saying makes sense... I am wondering why the front loader really has no reaction whatsoever... maybe due to weight?! Or is it that the real problem lies with the loader valve.
wore out
06-24-2020 17:06:28
 Re: John Deere 3010 Hydraulic De-stroke in reply to Rick3, 06-23-2020 18:39:56
[quote="CVPost-Rick3"](quoted from post at 16:16:57 06/24/20) I’m getting zero Psi without the lever activated and only 700 with it activated.[/quote]
You said "I scooped up a big load of gravel and took it/ dumped it and was going to back drag it with loader but it wouldn’t respond except to go down" and "used red" offered a good suggestion that something could have happened to the loader valve.
Have capped off the feed yet to the loader valve?
Until you you this, to be absolutely sure there isn't a high pressure leak to return there your tests at the remote couplings really don't mean anything, and there's no valid reason to wrench on the pressure control on the pump.
That being said, it may well be that the loader valve is just fine and the trouble IS in the pump, but IMHO, it would be prudent to rule out the loader valve BEFORE pursuing changes to the pump.
Rick3
06-24-2020 17:36:59
 Re: John Deere 3010 Hydraulic De-stroke in reply to wore out, 06-24-2020 17:06:28
Yes that is on the agenda. I wound up down thereyesterday and had a few minutes to mess with it. Got the right gauge fitting for the rear remotes and checked it. It’s probably going to be a couple weeks before I’m able to go back and take the loader out of the equation. I appreciate everyone’s help as I narrow down the cause of this issue.
Copyright © 1997-2020 Yesterday's Tractor Co.
