Company Logo Shop Now
Re: John Deere 3010 Hydraulic De-stroke
WTW
06-23-2020 07:21:04
Rick, The top Photo is the pump pressure adjusting screw as Tom stated. The bottom picture is the destroking screw. Where thing are confusing is the original pump in the 3010 the destrokeing screw is on the bottom and adjuster was on top / opposite of each other in same bore. Later replacement pumps the internal stroke control valve and these two features were revered from top to bottom, like 20 series and later pumps are. If your tractor does not have the destroke screw you simply remove plug on opposite side of adjusting screw and swap it with destroking screw that is readily available. As previously stated there is two different ones used depending on pump cover. DW
Rick3
06-23-2020 08:09:18
 Re: John Deere 3010 Hydraulic De-stroke in reply to WTW, 06-23-2020 07:21:04
Thank you for the clarification! It sounds like the pump on this tractor is a replacement pump... I will get a destroke screw and install in the top location.
WTW
06-23-2020 08:50:22
 Re: John Deere 3010 Hydraulic De-stroke in reply to Rick3, 06-23-2020 08:09:18
Rick, The destroking screw is a real good thing on hard / cold starting tractors. To use it correctly, when you want to shut pump off, loosen thumb screw and you will feel it turn easy for two or three turns before you will feel it contact internal stroke control valve. Once you feel it touch the internal valve only give it and additional 1/4 of turn. Do not crank down on screw hard as it is not necessary. All you have to do is crack the stroke control valve open! This method will prolong the life of the destroking screw and prevent unnecessary damage to internal stroke control valve. Enjoy! DW
Rick3
06-23-2020 14:48:21
 Re: John Deere 3010 Hydraulic De-stroke in reply to WTW, 06-23-2020 08:50:22
Thanks for the tip. Just checked my pressure at rear remote. Had 700+. Do I need to adjust stroke valve up while pressure is showing on gauge/ with lever engaged or with lever down/ disengaged and just turn 1/4 at a time?
Rick3
06-23-2020 18:27:55
 Re: John Deere 3010 Hydraulic De-stroke in reply to Rick3, 06-23-2020 14:48:21
I think I should clarify my earlier post... my question was meant to say when adjusting the pressure adjustment screw, do you check the pressure and leave the lever engaged so you can physically see the pressure go up As you turn the screw or do you check the pressure then disengage the lever, gauge goes to zero and adjust the screw clockwise some then recheck the pressure? I tried adjusting it up with it disengaged then rechecking the pressure but probably didnít turn more than one full turn with no gain in pressure.
WTW
06-23-2020 16:51:15
Rick, If standby pressure is that low good chance adjustment may not bring up to normal stall limit. Should take a turn or less to get it in range. Most often this is caused by a worn out / leaking stoke control valve. The valve and seat can be replaced in tractor if you know how to do it as I have done it many many times on many different models. The seat and valve is a assembly that is matched set. Kinda pricey but common to replace them on older tractors. If pressure cannot be achieved that is where I would go next. Set it to 2250 psi. DW
Rick3
06-23-2020 18:39:56
 Re: John Deere 3010 Hydraulic De-stroke in reply to WTW, 06-23-2020 16:51:15
I envision springs and small parts flying toward my face under that tractor! LOL! What you are saying makes sense... I am wondering why the front loader really has no reaction whatsoever... maybe due to weight?! Or is it that the real problem lies with the loader valve.
wore out
06-24-2020 17:06:28
 Re: John Deere 3010 Hydraulic De-stroke in reply to Rick3, 06-23-2020 18:39:56
[quote="CVPost-Rick3"](quoted from post at 16:16:57 06/24/20) I’m getting zero Psi without the lever activated and only 700 with it activated.[/quote]
You said "I scooped up a big load of gravel and took it/ dumped it and was going to back drag it with loader but it wouldnít respond except to go down" and "used red" offered a good suggestion that something could have happened to the loader valve.
Have capped off the feed yet to the loader valve?
Until you you this, to be absolutely sure there isn't a high pressure leak to return there your tests at the remote couplings really don't mean anything, and there's no valid reason to wrench on the pressure control on the pump.
That being said, it may well be that the loader valve is just fine and the trouble IS in the pump, but IMHO, it would be prudent to rule out the loader valve BEFORE pursuing changes to the pump.
Rick3
06-24-2020 17:36:59
 Re: John Deere 3010 Hydraulic De-stroke in reply to wore out, 06-24-2020 17:06:28
Yes that is on the agenda. I wound up down thereyesterday and had a few minutes to mess with it. Got the right gauge fitting for the rear remotes and checked it. Itís probably going to be a couple weeks before Iím able to go back and take the loader out of the equation. I appreciate everyoneís help as I narrow down the cause of this issue.
Copyright © 1997-2020 Yesterday's Tractor Co.
