Two Questions
jdr1943
I have a 430W John Deere i am restoring with a #44 trailer plow i can guestimate the length of the hydraulics hose from the tractor to the hydraulic cylinder but thought someone might have the correct length i don't like to have them to long next question not sure what this part is called part #X283-A it's the part that the inside sleeve slides into if anyone has a plow they are parting out or junked i would like to have this part.
THANKS
Is the tractor in pieces or all together? If together, the easiest way would just be to hook the plow to it and measure the length of hoses you need. Most dealerships are set up to custom make the length you need. Otherwise, a place like TSC or Fleet Farm has hoses in various stock lengths. Pick out the ones closest to what you need.
