Hotflashjr
- Location
- Western MA
So I bought the loader. After looking over the loader valve it is a
Gresen SPK valve that has down pressure for the main cylinders. I
took off the cap where the closed center plug should be and it is an
open center plug. So I learned Gresen is now Parker-Gresen and I
think finding the closed center plug is not possible. I think a new
valve is in order. I believe the one Briar Hill Britney’s poster would be
the correct valve and work fine.
I included a picture of the valve as well as the current set up for the
home brew hydraulic outlets. Can I add a T fitting in the current set
up to hook up the loader and keep the hydraulic outlets?
