Company Logo Shop Now
Engine problem John deere 40
mikemul
06-22-2020 06:16:44
i have a problem with my john deere 40, when the tractor idles there is no problem. only when you accelerate it starts to pop softly. it runs at a fixed speed but through that you hear a popping sound every now and then. who knows what this can be? I have already put new bows and bows caps on it.
Roy Suomi
06-22-2020 11:59:46
 Re: Engine problem John deere 40 in reply to mikemul, 06-22-2020 06:16:44
Been sitting for a while ? Maybe valve sticking ?
M-MAN
06-22-2020 10:16:54
Don't know what you mean by bows and bow caps.
Of course you would start with new points and plugs. Check your timing. Adjust your valve lash." sounds like they may be too tight ". If that doesn't fix it there is probably a hole burned through in the manifold.
rusty wheel
06-22-2020 09:22:59
Might need a valve job.
ET
06-22-2020 09:18:41
Ignition problem, start with new plugs.
Maw7989
06-25-2020 20:14:01
 Re: Engine problem John deere 40 in reply to ET, 06-22-2020 09:18:41
My 630 was doing the same thing. When I pulled the wire off number 2 plug it wouldn't idle on number 1 only but would run roughly at higher rpms. Pulled carb and deep cleaned it and it runs like a top. I thought ignition too. New plugs, made new wires, new cap and condenser.
Copyright © 1997-2020 Yesterday's Tractor Co.
