Company Logo Shop Now
2940 steering
dwamsley
06-21-2020 13:42:24
I am having a steering issue with my 2940. The steering is harder to turn then normal, I am assuming emergency steering. 3pt, pto, hi/lo, remotes and brakes all function normally.
I will also add that it started making a chattering noise like a hydraulic line vibrating on the right side. Only did it at higher rpm 1500 and above. I changed hyd filter, steering filter, cleaned screen and put in new fluid today. Screen and filter looked ok. The chattering noise is now intermittent, but steering issue still exist. No change with pto on or off and no change in hi or lo.
Any ideas on the issue? Could it be steering motor/valve?
dwamsley
07-02-2020 11:41:35
 Re: 2940 steering in reply to dwamsley, 06-21-2020 13:42:24
Thanks guys for the info. After reviewing the description and operations of the hydraulics in the manual I am going to looking to the steering valve as the possible culprit. It seems if I had a hydraulic pump issue fluid pressure would be to low to go past the priority valve and 3pt/remotes wouldn't work. I assume a steering valve issue could hurt flow enough to cause a chatter. I have some gauges on the way to check pressures. I will report back what I get figured out.
Tx Jim
07-02-2020 11:07:12
b&d
You must have overlooked this part of dwamsley's post.
buickanddeere
07-02-2020 10:37:33
Front pump shaft spline or the coupling splines have been known to wear and fail .
Tx Jim
07-02-2020 03:55:55
If dual cylinders are the problem they should leak oil out the seals at the end of the barrel. Due to the fact your tractor has dual cylinder steering I think steering controller is at fault which I have no experience with. I'll suggest to acquire/study a 2940 tech manual.
dwamsley
07-01-2020 17:58:51
Is there anyway to test the steering cylinders for internal leakage?
dwamsley
07-01-2020 17:56:57
Tx Jim I assume you are meaning one of the 2 front steering cylinders may be leaking. My tractor is a 1982 model so the last year for the 2940. It has the orbital valve under the steering wheel with the 4 hoses left, right, pressure and return. Is there anyway to test the valve? Has anybody here used the Midwest steering valve its about 1/2 the price of the eaton.
dwamsley
06-27-2020 06:36:49
My tractor has 2 steering cylinders and has been greased.
Tx Jim
06-27-2020 03:38:36
Welcome to YT
According to JD parts 2940 has hydrostatic steering & either has 1 or 2 steering cylinders but has no steering motor. My guess is steering cylinder piston seal is leaking internally. Has both steering knee swivel areas been greased regularly?
dwamsley
06-26-2020 22:35:52
Anyone have any recommendations?
Copyright © 1997-2020 Yesterday's Tractor Co.
