Company Logo Shop Now
Deere 2440 pto issue
NEPA ED
06-21-2020 12:18:13
My JD 2440 pto spins but no torque. The lever that engages the pto works fine. As I pull up on the lever by the shifter rpms increase but if I pull up too far (i.e. I cant lock it in place) the pto will stop spinning. Also when spinning slow it doesn't spin smoothly. Kind of stutters as it spins. No abnormal noises. Prior to this issues starting I was drilling holes with a post hole digger. Any thoughts?
NEPA ED
07-22-2020 09:51:07
 Re: Deere 2440 pto issue in reply to NEPA ED, 06-21-2020 12:18:13
[quote="Tx Jim"](reply to post at 03:27:42 06/22/20) [/quote
Pressure test was good. Took off the pto valve. Small snap ring was missing which I replacedthen reassembled but did not help.
Split the tractor yesterday. Snap ring that holds the clutch pack in was in several pieces. Going to take a week for a new one to come in. I'm certain that's the cause of my issue. Just wondering why it shattered like that. I have a dozen more holes to auger and dont want it to happen again.
Tx Jim
06-22-2020 03:27:42
I can't remember if hyd pto valve housing has hyd test port. I suggest to acquire a 2440 tech manual. If pressure is within spec's(155 psi) I'll guess linings are worn.
NEPA ED
06-21-2020 17:57:17
And yes, 3 pt and power steering work correctly
NEPA ED
06-21-2020 14:00:38
I changed all fluids hyd, oil, antifreeze and filters. Cleaned the screens - hardly anything in them last summer. Guy I bought from told me he had recently changed them too but I wanted to be sure. I've brush hogged 50 acres last year and drilled 20 or holes with the auger until it acted up.
Tx Jim
06-21-2020 13:07:38
Welcome to YT
By your stating "pull up on pto lever" your tractor must have ind hyd pto. How long since hyd filter was changed & hyd sump screen checked/cleaned? Does 3 pt & power steering operate correctly?
Copyright © 1997-2020 Yesterday's Tractor Co.
