Model 50 piston rings
Need to know the proper placement of the piston rings on a john deere model 50. Have 5 rings, one chrome. two dark colored that appear to be the same, one dark colored one with a ridge on it and a large oil control ring. Ring set is part number AB4958R. Thanks!
No instruction sheet? Chrome is on top, oil on the bottom I don't know what you mean
with the one with a ridge on it???? Look for a dot, as that goes to the top.
Trying to help a friend, the rings have been taken out of box in no certain order, no info in the box that i saw. From the info i have received should the correct order be chrome on top, then the two dark colored rings then the one dark colored one with the ridge and last the oil ring. All dots facing the piston top. Thanks!
