Archerdude
New User
I have a 4020 with a problem I've never heard of before. I just had the clutch rebuilt. Both the trans and pto would not disengage. A local shop did the work. The mechanic only works on older deere tractors and he is very good. He said the housing had a lot of rust in it when he split it. When i got it back everything works properly with one twist. When you let the clutch out the pedal returns to within a half inch of the stop. The wheels drive fine but the pedal is not touching the stop. If you reach down and pull it back it pops to the stop. Has anyone seen this?
