‘70 4020 CB injector pump o-rings
Ole_Jonny
New User
1970 4020 with a CB pump on it. It leaking fuel from where the throttle linkage hooks to the pump. Anyone have a good part # for this?
There are two O rings under the throttle lever assembly that hold grease in for the rack and pinion, the O ring that's leaking fuel is deeper inside on the rack itself. Most fellows just replace the two O rings and hope the leak stops awhile.
Replacing the 2 o-rings at the rack and pinion was the plan. Dad’s been to the JD dealer and got new o-rings and they weren’t the correct ones. The ones they sent wouldn’t have even held in grease. I can’t find a good clear exploded diagram to see what lies below the rack and pinion. Thanks for the reply, I’ll keep looking and learning.
