Dan Nickels
Always had a slight howl coming from (I think) pulley/clutch
area on my 620. tedding hay yesterday, howl got much louder
(lessens when clutch is disengaged). I/T shop manual showed a
bearing on the pulley assembly and I wonder if this bearing may
be dry and making noise. I was thinking pull off pulley and
check/grease bearing.?.? Neighbor says to pull off pulley, rear
wheel has to come off to provide clearance. I/T shop manual does
not mention that...Has anyone had experience with this bearing
and/or removal of pulley ?? Thank you... Dan
