Company Logo Shop Now
mODEL 60 CLUTCH
John Bouchard
06-15-2020 17:38:22
What is the problem with the clutch if it doesn't "snap" in place to engage. When I tighten more, it doesn't engage, less it just snaps out by the wt of the handle. The T bolts and toggles are new replacements. Is the problem with the sliding collar in the clutch?
J Bouchard
06-16-2020 08:35:33
 Re: mODEL 60 CLUTCH in reply to John Bouchard, 06-15-2020 17:38:22
clutch has been apart and cleaned. Brass engaging collar was broken at one time and replaced. Never worked right since. Trying to get it working the way it is supposed too since that replacement.
JIM MN
06-16-2020 08:11:11
Check operating sleeve locating tab-hole and pin; is hole egged-out and pin worn; lets dogs and toggles move around causing no snap.. If this is good; need new both three dogs and three toggles, grease up and install.. No snap is usually dogs and toggles..
buickanddeere
06-16-2020 07:36:29
When was the last time the pulley, the driver and all the disks were removed from the tractor ? Cleaned and inspected ?
Mike M
06-16-2020 06:03:46
If the sliding collar (operating sleeve)moves around on the locating pin from wear it will give you fits trying to adjust it.
Copyright © 1997-2020 Yesterday's Tractor Co.
