Looking for JD mechanic
chas036
I have a 720 diesel electric start and I am looking for someone in upstate NY or northeast PA who can do an engine rebuild like replace the rings and injectors, and replace the bearings. I believe it needs
bearings because after it warms up, the oil pressure will drop to 10 lbs , ad that is with straight 40wt oil. Yes, i have hooked up a calibrated oil pressure gauge, so I know that the pressure is truelly low
Be prepared to spend more money on it than the tractor is worth ! Even if you do the work yourself.
If it drops to 10 psi at idle, is quiet and does not smoke, I would leave it be.
Otherwise bring your wallet, my guess would be above 5 grand.
