Company Logo Shop Now
Re: JD 650 Governor/Injector pump issue
joeboots
06-14-2020 19:07:45
That makes perfect sense. Thank you very much. It is quite possible I installed the plungers backwards. I had never rebuilt one of these pumps before and while putting it back together I questioned which way they went back in. The governor assembly seems perfectly fine thats why I was going crazy. Thank you again for taking the time to explain I will be taking the pump apart next weekend and will let you know what the outcome is.
Dieseltech
06-14-2020 19:15:01
 Re: JD 650 Governor/Injector pump issue in reply to joeboots, 06-14-2020 19:07:45
Being in diesel pump repair over forty years and counting, I've seen it happen before. Also if the rack and gear segments are not meshed correctly, that will cause trouble too. Some pumps use ball end with rack notches to eliminate the problem gears/rack teeth misalignment..
Copyright © 1997-2020 Yesterday's Tractor Co.
