Company Logo Shop Now
Re: JD 650 Governor/Injector pump issue
joeboots
06-14-2020 18:32:13
So just pull the pump swap the plungers and try again?
Dieseltech
06-14-2020 18:59:43
 Re: JD 650 Governor/Injector pump issue in reply to joeboots, 06-14-2020 18:32:13
If you're SURE the governor is right. All inline pumps have barrels and plungers mated to each other, Bosch P size pumps plungers are non directional, will work either way as barrel has two holes and plunger has two helix to control fuel delivery. Other inline pumps the plungers are directional, barrel has one hole and plunger has one helix. Plunger helix MUST be on the barrel hole side to control fuel delivery, installed 1/2 turn off places helix away from barrel port, meaning NO fuel control at all. So, if EITHER plunger is installed 1/2 turn off, OR the barrel installed 1/2 turn off WILL cause no fuel control.
Copyright © 1997-2020 Yesterday's Tractor Co.
