Company Logo Shop Now
Re: Repairing 9250 backhoe valves
Jim.ME
06-14-2020 05:27:38
I would agree with Tx Jim. This is where doing diagnostic checks before tearing things apart is prudent. First thing you should check, if you haven't, is to confirm the valve is moving the same amount in both directions when the control handle is moved. Another quick check that often helps determine a valve vs cylinder problem is to swap the hoses at the valve (or cylinder if access is easier). If you can swap the two hoses, that go to the cylinder, so the cylinder works the opposite way when the control handle is moved from the way it works now and try it. If the cylinder still creeps going left and swings ok to the right the problem is likely in the cylinder. If it creeps right and swings left it is likely an issue in the valve.
Copyright © 1997-2020 Yesterday's Tractor Co.
