Dougin texas
On 535 baler the cylinders that hold gate closed, one will creep open, I have rebuilt the cylinder twice and continues to do the same thing. Question the block that is on the baler under the cover there in the front, is it possible to have a leak or something else internally in the block cause the gate cylinder to not stay in closed position.
It you keep bumping the SCV to keep cylinder closed and you get some hay in baler and see the pressure gauge on the baler jump up, the cylinder will stay in closed position.
