Company Logo Shop Now
Re: 3020 engine swap
MikeJM
06-07-2020 11:42:31
I did a comprehensive set of posts a few years back on a 239 swap.
The short list is you need the back plate and front pump support from a 4030. Pump drive from a 4230. Depending on what your 239 came out of you may need to change the front pulley and water pump to the smaller one used on the Dubuque tractors.
To get the flywheel on to the crank youll need to have an adapter fabricated half inch thick and the flywheel modified.
Frame rails need to be modified to bolt to the new adapter plates.
tomstractorsandtoys
06-09-2020 11:27:26
 Re: 3020 engine swap in reply to MikeJM, 06-07-2020 11:42:31
I was told that if you use a 2510 hyd pump bracket you can also use the 2510 frame rails. Never have done one but have thought about it. Tom
Mauldin1
06-07-2020 14:58:11
What modifications have to be made to the flywheel? Did you use the 3020 flywheel or a different one?
Copyright © 1997-2020 Yesterday's Tractor Co.
