Company Logo Shop Now
Re: 2510 engine swap-question
WTW
06-07-2020 07:53:14
The original oil pan is part of the tractor chassis structure and is very important because of the limited frame to engine mounting surface /strength along with block strength. Original pan is made very heavy and bolts to the clutch housing circle for support. I am currently installing a 276T in a 2520, same / original pan held a gallon less oil. New engine held more oil. I wanted the same for the bigger engine. I found a oil pan from a 23,25, or 2755 gave me an extra gallon of oil over original pan, bolted up to engine and clutch housing circle and is structural in design. Hard to find and did not come cheap! I would not recommend not using a structural oil pan. If your 276 pan is structural / Cast iron and bolts to clutch housing your good to go! The water pump is different on the short stroke 202 because there is no water port for engine oil cooler water line to connect to. You may be lucky if the water pump on the 276 has same fan center line to crankshaft??. There is allot of different water pumps with different center line mountings, don't know which one you got?? These engines do not use pulley harmonic balancer. Just a pulley. The pulley's can be swapped and original pump coupler can be reused. Or if you want you can update with newer style pump drive but drive shaft is pricey! DW
Copyright © 1997-2020 Yesterday's Tractor Co.
