WeirdDeere
Dan in Ohio and anyone else that knows...
The 45 loader on my 60 leaks pretty good out of the front of the cylinders (where the rod goes through). I bought lip seals and O rings to seal it up. I don't really want to disassemble the whole thing just to do it, am I right that I can block up the loader, un pin and retract the cylinders, then take that cap off to replace?
Looks like just a roll pin for the yoke, and then the 3 nuts on the tie rods and it should come off, right?
It looks simple, but I haven't had a simple job go easy yet on this tractor. Some rewiring ended up killing my good charging system, and a new regulator hasn't fixed it, yet I bypass it and it works just fine. Ugh.
Brandon
Brandon
