Company Logo Shop Now
Planting
Navajo350
06-06-2020 06:52:24
Late start and first time here, but planting corn with a JD 530 and a 490 planter. What gear/speed should I use?
Thanks,
Bob
JIM MN
06-08-2020 12:12:13
 Re: Planting in reply to Navajo350, 06-06-2020 06:52:24
If you don't have the operators manual for your 530 tractor for gears and speeds, here's a little help.. third gear- open throttle -is about 3.5 mph--- forth gear is 4.5 mph--- fifth fear is 5.8 mph- plus or minus.. Pick a gear to give you the best speed to get your wanted seed placement as the others have suggested....
DR. EVIL
06-07-2020 07:14:59
Dad normally ran 4-1/2 to 5 mph with our 490 planter. We Hill Dropped all our corn, 3-4 seeds together in the 38 inch rows every 2 ft or so. The last two years he farmed he raised some soybeans. I can't imagine soybeans growing well if planted by hill-dropping, so I imagine they were planted a seed every 3-6 inches, I cultivated them, I should know for sure, but 48 to 50 years later some details have escaped me. I do remember the last field we planted the last year Dad farmed, we fall plowed every square inch of the farm the fall before. Following spring we disked everything and were ready to plant. That last 20 acres worked up like a sandbox, no clouds bigger than a small marble. Dad had to stop and adjust planting depth 4-5 times in the first 40 rods. The planter with full seed boxes was burying the seeds! Those old sled runners were not good at controlling planting depth like today's double disk openers.
Brendon-KS
06-07-2020 04:30:21
With plate planters the maximum operating speed is dependent on how fast the seed plate needs to turn in order to get the desired population. If the plate is turning too fast the seeds won't get into the cells properly and you'll get skips. As an example, for a given population a 24-cell plate will be turning slower than it would be with a 16-cell plate which might allow for a little more ground speed. Ground conditions obviously make a difference too - in really rough ground you'd need to go a little slower. For an "typical" speed with a plate planter I'd say somewhere between 3 and 5 mph.
MikeinKy
06-10-2020 05:35:22
 Re: Planting in reply to Brendon-KS, 06-07-2020 04:30:21
Fourth gear
Copyright © 1997-2020 Yesterday's Tractor Co.
