Company Logo Shop Now
Re: JD 3010 hydraulic pressure, flow rate
wore out
06-06-2020 06:25:50
As I wrote in my earlier post, 18 GPM is MAXIMUM pump output.
Since this is a closed-center system your control valve does NOT have to flow the full volume of the pump. (As an open center system valve has to.)
IIRC, the individual 3010 MCV's flow 6 or 8 GPM's EACH.
As another poster said, lower GPM valves may be easier to "feather", so you MAY want to stay a size below a valve that's rated for the full GPM of the pump.
If the flow is adequate for the loader it should work well, and will have no ill effects on the closed-center pump.
svcummins
06-07-2020 16:35:11
 Re: JD 3010 hydraulic pressure, flow rate in reply to wore out, 06-06-2020 06:25:50
3010 is 16 gpm 3020 is 18 gpm from the factory service manual
Copyright © 1997-2020 Yesterday's Tractor Co.
