Company Logo Shop Now
Re: 45 Loader cylinder disassembly
Dan in Ohio
06-06-2020 04:10:48
Brandon,
My recommendation is to take the cylinders off the loader and work on a bench as it is handy to have access to a press. Blocking up that loader sounds dangerous to me. When I worked on mine I did two loaders 45 and 45W at the same time taking cylinders off and leaving the loader on the tractors. I believe it would be easier and safer in the long run.
Be safe and work in the comfort of your shop out of the sun, the rest is fun. LOL
Dan
Weirddeere
06-06-2020 06:51:55
 Re: 45 Loader cylinder disassembly in reply to Dan in Ohio, 06-06-2020 04:10:48
When I mention blocking up the loader, I meant to rest it with the bucket slightly off the ground, so that the cylinders could be retracted enough to be removed, not really working under it. Though I do have a set of C Channel made to hold the loader up in the air during winter storage so it takes up less space. Those slip over the cylinder rods and then the weight rests on the C channel. That wouldn't work for the job I need to do.
What part of the cylinder requires a press?
Now if you can get the kingpins out of my 80, that would be awesome
Brandon
Dan in Ohio
06-06-2020 09:08:49
 Re: 45 Loader cylinder disassembly in reply to Weirddeere, 06-06-2020 06:51:55
Just took a look at my loader and think what you plan to do would work safely. Knowing you are about half my age negates the pain in knees and back that will result from your method. Let us know what you decide, hope it goes good.
Dan
PJH
06-06-2020 06:47:59
That roll pin that Dan shows in his last picture should fit tightly. On one of my loaders for some reason they were only finger tight. You can run a safety wire through the center of the roll pin and wrap/tie it around the outside to prevent it from working out.
I agree with Dan about removing the cylinders to work on them. Once you start taking it apart you might as well redo the piston too.
Copyright © 1997-2020 Yesterday's Tractor Co.
