Company Logo Shop Now
Petronix Super coil resistence
mdross
06-05-2020 07:13:18
We installed a Petronix ignition and a Super Coil with 3.0 ohms resistence it also needed a 2.0 ohm resister. I have another Super Coil it has 1.5 ohms resistence do I need a 3.5 ohm resister for it to work?
JDEM
06-05-2020 14:47:22
 Re: Petronix Super coil resistence in reply to mdross, 06-05-2020 07:13:18
Pertronix Ignitor I when used on a two-cylinder engine calls for a coil with a minimum of 3 ohms primary resistance. Subsequently, to use that 1.5 ohm coil, you have to add a ballast resistor with at least 1.5 ohms resistance.
John T
06-05-2020 12:52:10
The electronic switch you chose has a certain current rating so the coil current (which depends on its resistance) cant exceed that. Anytime a Pertronix question is asked here I always advise to check with them NOT US regarding coil and switch and plug wires to use.
Don't take a chance with that expensive switch.
John T
buickanddeere
06-05-2020 09:34:12
6V or 12V system ?
tractor equipped with bypass starting ?
If the tractor does not use bypass starting. Using a low resistance coil and a ballast gains absolutly nothing.
if 12V and no bypass starting . Use the 12V 3.5 to 4.0ohm coil and no ballast.
JDEM
06-05-2020 09:31:42
There is no correct answer for you question unless you tell us which specific version Pertronix Ignitor you have. I, II, or III?
mdross
06-05-2020 12:11:22
 Re: Petronix Super coil resistence in reply to JDEM, 06-05-2020 09:31:42
Mine are Petronix Type I, 12 volt negative ground JD 60 and 70 with 1.5 ohm Super Coil.
mdross
06-05-2020 13:19:18
 Re: Petronix Super coil resistence in reply to mdross, 06-05-2020 12:11:22
I should add that both the 60 and 70 have had the Petronix I installed for several years running stock coils 1.5 ohm. It's time to add in the Super coils. The one Super coil I have is a 1.5 ohm coil.
Copyright © 1997-2020 Yesterday's Tractor Co.
