Company Logo Shop Now
TractorLinks.com
Re: 3020D clutch adjustment while on tractor
miangus
06-02-2020 15:45:55
I changed out the pro fingers on my 4020 and got them adjusted through the bottom so I expect you could adjust the engine clutch through the bottom. I would start by spraying the clutch area with parts cleaner letting it soak then power wash the clutch area with the tractor running. Carefully inspect the fingers for damage, if one is damaged or bent it will not release. Check the pins. Can you start and run it with the tractor in gear and the clutch down. The clutch disk could be damaged. Maybe time to split. Be careful!
Copyright © 1997-2020 Yesterday's Tractor Co.
