3010 hydraulic pump coupler
Olliejunkie
I had mine apart for some reason and replaced the bolts. Thought about changing it over to newr style but if my memory serves me right the parts were expensive. I really like this tractor but the chatter of the pump coupler is a little annoying. Does anyone know of a inexpensive replacement update kit?
Shown in photo below are the prices for newer style hyd pump drive from local JD dealer. I'll suggest to check A&I prices or other aftermarket sources.
Did it quiet it down much? Sometimes my pump takes awhile to activate after I start it. Sure makes alot of noise when it starts working. I did see some parts online that seemed reasonable compared to deere. Maybe I will look into it some more. It's been awhile so I cant remember everything that needs changed.
My 3010 fan belt broke last fall. My coupler was in good shape but for the life of me I could not reinstall it. Therefore I bought the new style coupler. Going off
memory- the 4 rubber bushings were about $10 or $11. The 2 coupler halves were around $30. The other hardware nuts and bolts were pennies. So lets say $45. You could do
that or I would be happy to sell you my original 3010 coupler for half that money. I decided to get a real good fan belt so I do not have to go thru the coupler removal
process any time soon so the whole operation was a lot more expensive than I thought when the fan belt broke and I thought I would go down to the NAPA store and spend $8
to fix the problem......
When I first started restoring my Dad's ol 3020, it took me a bit to figure out the pump coupler was shot, when I took it apart there were no
rubber parts remaining, just bolts on metal so you can imagine how it was rattling. The housing was to worn for the new rubber bushings but
one I bought all new stuff it was like a whole different tractor
(quoted from post at 07:46:42 06/02/20) My 3010 fan belt broke last fall. My coupler was in good shape but for the life of me I could not reinstall it. Therefore I bought the new style coupler. Going off
For some reason I thought I had to replace more than that per the john deere parts man. Of course that was long ago before you could look everything up on the net. Is it much quieter now?
