Company Logo Shop Now
TractorLinks.com
need deere part ar44388
huntertod
06-01-2020 16:45:27
I'm working on a deere 4020 with front wheel assist. I'm looking for the tee that fits on the right side of the hydraulic pump (3" pump). Its part AR44388. Deere does not have any, not in obsolete depot or vintage. Anyone have one or know where I can get one? Thanks, Perry huntertod@outlook.com
Jim.ME
06-03-2020 05:24:19
 Re: need deere part ar44388 in reply to huntertod, 06-01-2020 16:45:27
Here as a shot of the drawing.
Jim.ME
06-03-2020 05:23:10
I am guessing you confirmed your pump size and the fitting as I see there is a different fitting (AR53565) listed for the larger pump and replacement pumps for item key 7 in that same diagram.
If the fitting coming out of the pump is a true 45 for the top run, you should be able to get that at a hydraulic shop. Get a 90 degree elbow fitting the right size for the lower branch and have a machine shop use the outlet side of it to "marry" on to the base fitting to duplicate your current fitting.
What happened to your original fitting?
One would need to see the space but possibly adapters and other fittings could be used but likely would also require changing some steel tubes, if that is what hooks to it now, to hoses.
Scott 730
06-02-2020 17:20:05
Post a picture of your part here. It may help someone figure out something that will work.
Cliff Nelson
06-02-2020 05:51:24
Try to spec it out through a hydraulic supplier. Most fittings are available aftermarket if you know the size and configuration.
huntertod
06-02-2020 17:05:42
 Re: need deere part ar44388 in reply to Cliff Nelson, 06-02-2020 05:51:24
I went to a couple of hydraulic fitting suppliers. I showed them the old part and they looked at me like I was from the moon. No luck!
matthies
06-02-2020 20:59:24
 Re: need deere part ar44388 in reply to huntertod, 06-02-2020 17:05:42
I looked at jdparts and it is an odd one!
Tx Jim
06-02-2020 04:14:43
Perry
Have yo checked for hyd fitting availability at any salvage yards?
huntertod
06-02-2020 17:07:53
 Re: need deere part ar44388 in reply to Tx Jim, 06-02-2020 04:14:43
I have checked salvage yards. I have yet to find a 4020 with FWA that was salvaged. They are all 2 wheel drive and the part I need is specific to the FWA system
Copyright © 1997-2020 Yesterday's Tractor Co.
