Company Logo Shop Now
TractorLinks.com
50 series steering
Johnboynotbilly
05-31-2020 18:47:30
A few months back my Uncle Bill and I were pulling off my 50 to get it started. I ran into the back of the G after the 50 cranked up and it smashed the wheels all the way to right real hard. I was glad I didn't have my thumbs inside the steering wheel. Every since then, it has been real.hard to turn it back to the left. Turns to the right okay though. Anyone have any thoughts on what could be wrong, what to check?
Johnboynotbilly
06-02-2020 09:17:18
 Re: 50 series steering in reply to Johnboynotbilly, 05-31-2020 18:47:30
Correct, it has manual steering. I replaced the rear worm gear bearing yesterday and it did not improve at all. Does anyone know if someone offers a steering pedestal rebuild kit?
fixerupper
06-01-2020 19:28:10
His 50 has manual steering. No power steering lines there.
Johnboynotbilly
06-01-2020 06:29:53
Which valve are you referring to?
ET
06-01-2020 10:51:09
 Re: 50 series steering in reply to Johnboynotbilly, 06-01-2020 06:29:53
It's on the right side of the worm gear housing. It has 2 steel lines going down to the rotary cylinder and a rubber pressure line feeding it.
ET
06-01-2020 06:12:27
I think when you smashed in the nose it moved the steering valve adjustment back slightly. You need to recenter the steering valve.
Johnboynotbilly
06-01-2020 05:39:51
Manual.
deeretails
06-01-2020 04:40:46
Manual or power steering?
Johnboynotbilly
05-31-2020 19:13:43
That makes a lot of sense. I'll check that tomorrow afternoon. Thanks.
Paul_IN
05-31-2020 19:02:26
It may have damaged one of the bearings on each end of the steering shaft gear when the wheels jammed to full lock. The other bearing is still okay and able to take the thrust load when you steer left.
Copyright © 1997-2020 Yesterday's Tractor Co.
