Deere & CO
New User
Hi Everyone! I'm new here, and this is my first post. If this topic ought to be moved to a different subform, I hope a moderator can take care of that. I'm very familiar with car forums, but tractor forums are a new for me. Anyway, down to business.
I have a ~1987 2150 with a 146 loader on it. The past few days I have been working on getting one of the rear wheels repaired and re-ballasted. The tractor was parked outside with a tarp over the central controls, seating area, and instruments cluster. After completing the wheel repair, I started the tractor and noticed a whine from the hydraulics, it seemed. It went away after a little bit, but I then noticed that when I shut down the tractor and attempted to lower the loader by releasing the pressure in the system, the bucket would not even lower or it would lower extremely slowly. I attempted this multiple times after moving the bucket through its entire range of motion several times. I had driven the tractor, let it idle for near 15-20 minutes, and still the same situation. I verified proper amount of hydraulic oil, and the oil that I removed when pulling lines to check for blockage appeared fine with no particulate or severe discoloration. I can hear a bit of a whine from near the side of the transmission, like fluid squeezing through a crevice, when I lower the loader with the tractor off (if it does lower). Recently, I put a new hydraulic fluid filter in, but I hadn't done the screen (just discovered that one this evening ). Everything appeared to be fine after that service a few weeks ago. I also have fitted a few new hydraulic hoses and such, but those didn't cause any issues for a while, so now seems like an odd time.
I attempted to poke around in the metering/control module that the loader control lever manipulates. Removing the fittings for the main lift hydraulic cylinders didn't reveal any odd details or contamination to me. I don't know where to go from here. Short of digging deep into the trans and hydraulic system, something I'm not ready to do, I don't know what could be causing this. Do any of you hydraulic experts know what could be going on here?
Thanks,
Tim
Thanks,
Tim
