Company Logo Shop Now
TractorLinks.com
Re: 4020 coolant in oil after rebuild
mmfarms
05-20-2020 14:34:03
Turns out it was the head gasket. Put a new one on and torqued to 130 this time. Will see how it holds
Having another issue however. Got it running, and after running about 20 minutes it is starting to throw oil out of the exhaust manifold. Is this a normal part of breaking it in?
Tim S
05-20-2020 16:04:58
 Re: 4020 coolant in oil after rebuild in reply to mmfarms, 05-20-2020 14:34:03
That is normal, and you will need to ad some break in additive with Zinc in it to get it to break in. You can get a bottle of it at most auto stores.
mmfarms
05-20-2020 16:41:23
 Re: 4020 coolant in oil after rebuild in reply to Tim S, 05-20-2020 16:04:58
I am using John Deere Break-in Plus. Is it still necessary to use an additive? I'm not at the shop right now to check the bottle.
Tim S
05-20-2020 17:45:33
 Re: 4020 coolant in oil after rebuild in reply to mmfarms, 05-20-2020 16:41:23
That will be okay to use, you will need to let it run a bit and warm up to start the break in process it will wet stack for a bit.
Copyright © 1997-2020 Yesterday's Tractor Co.
