Company Logo Shop Now
TractorLinks.com
Re: 2150 Slow Hydraulic Pressure Realease
Deere amp; CO
05-20-2020 05:02:18
Hi Tx Jim! Thanks for the welcome.
I will definitely be ordering that hyd sump screen asap. It would seem odd that it would cause excess back pressure on the loader hydraulic release, but it still needs done. I don't know what type of valve options there are. It appeared to have a plunger that moves between a neutral position to allow fluid to flow directionally. I can grab a picture of the control valve module if that would be helpful? I did remove the quick disconnects and relived the pressure by pressing the steel balls up against a surface, and the fluid came out of the lines freely. I also removed the female end on the valve controls, and no apparent obstruction was found there. The balls all appeared to seat properly, and fluid seemed to flow through it just fine with the quick disconnects connected to one another, but disconnected from the valve controls. Is it likely an issue with the female ends of the quick disconnect that is hard to track? If any pictures or videos would be helpful (assuming the forum supports the attachments?), I can grab those, no problem.
Copyright © 1997-2020 Yesterday's Tractor Co.
