Company Logo Shop Now
TractorLinks.com
JD4430 Steering Leak
Rich.Fl
05-19-2020 11:31:37
I have a leak in the steering metering pump on this 4430...picture attached. It looks like it is coming from where the arrow is, but looking in the archives I see there is a seal around the column that can be a problem as well. First time I have looked at any of this so could use some suggestions. I better start by asking how difficult is it to get the pump out and work on? (Serial #04734412.)
Thanks!
Rich
wore out
05-19-2020 14:19:34
 Re: JD4430 Steering Leak in reply to Rich.Fl, 05-19-2020 11:31:37
It's not really a big deal to get the column out to work on it, there's special alignment dowels available to aid in assembly of the pump sections to avoid damaging the delicate Mylar gaskets.
I use the shank end of a couple of drill bits that fit snugly in the the holes of the stacked sections.
Rich.Fl
05-22-2020 02:14:51
 Re: JD4430 Steering Leak in reply to wore out, 05-19-2020 14:19:34
Thanks Wore Out! As you said came out easily. Have mylar gaskets ordered...and drill bit for alignment tool is a good idea.
Rich
Tim S
05-22-2020 04:51:37
 Re: JD4430 Steering Leak in reply to Rich.Fl, 05-22-2020 02:14:51
take a good look at the check valve in bottom, I have seen them go bad.
Rich.Fl
05-22-2020 15:12:25
 Re: JD4430 Steering Leak in reply to Tim S, 05-22-2020 04:51:37
Will Do...Thanks!
Rich
Copyright © 1997-2020 Yesterday's Tractor Co.
