ronnie wheat
Had the guy come and pick up tractor that done the brake job. He found a used complete brake cylinder,told me i had a crack in one of my original cylinder.He had to pump up both brakes before he unloaded it.I said no way i'm going to have that. he told me to run it a few days and see if it didn't improve. it didn't .called him out to farm he adjusted brake pedals got it better.let sit for 10 minutes no right brake,let it sit for 30 min. both pedals go to floor.with tractor running. he told me to drain all hyd. fluid out and fill with diesel fuel work all functions . drain and fill hyd oil. then call him because i had both equalizer valves with medal under the balls.when that tractor went to him the first time with medal to medal brakes i never had a pedal problem.
