Company Logo Shop Now
Re: JD CT 322 with locked up breaks
jd2cylman
05-17-2020 12:37:36
If the JD's are anything like NH machines, your park brake is operated by charge pressure, not system pressure. So, a minimum of 200psi. Probably should be in the 350ish range. When you replaced the brake solenoid, did you replace the whole solenoid and valve cartridge, or just the magnet coil? I've had the valve inside the cartridge stick before. More heat would make the cartridge stick possibly. That's all I can offer at this point. I'm a NH skid mechanic, so apples/potatoes... :wink:
Copyright © 1997-2020 Yesterday's Tractor Co.
