LipRipper3006
What is the largest bore that would be good for standard-sized rings? I have the block and pistons at the machine shop for measurements and am wanting to know what I should tell him given the measurement he tells me. He estimated at least .010 of wear but I can't find anyone with aftermarket .045 over pistons, so it's either new rings or sleeve the block back to STD size.
If I do end up going with sleeving how much larger should the bore be than the pistons? I heard JDs like to run loose compared to normal engines. It will be about $100 per cylinder plus rings so it seems to be less than buying aftermarket aluminum pistons.
Thanks
Thanks
