Company Logo Shop Now
Re: John Deere 420 Crawler fuse
wore out
05-15-2020 17:23:27
"If it were me, I would take the fuse out and hook the lamp across the fuse connectors."
That's what I suggested.
I give up.
Bookman
05-15-2020 21:09:28
 Re: John Deere 420 Crawler fuse in reply to wore out, 05-15-2020 17:23:27
I used a test light instead of a lamp. When I turned on the switch with either of the front lights connected, the test light lights up. I took both the lights apart but I do not see anything. I traced the wire from the front lights back to almost to the switch and did not see anything. I need to get my fat fingers in behind the dash and disconnect the tach so I get enough room to see the backside of the combination switch. Now suppose I could run a wire directly from the negative side of the battery to the front lights to test them....if that would not burn out a bulb. If they work, then I assume something in the wire or at the switch. Patience folks. Thanks
Copyright © 1997-2020 Yesterday's Tractor Co.
