4440 front tires 3 rib vs 4
Tom P
Any thoughts on what tires to put on the front of a 4440. We currently have 4 rib and need to replace them. Do 3 rib turn better during tillage? pros or cons of either?? Thanks
I think the 3 rib will turn a little better in soft ground, yes. My 4040 had 3 rib on it when I bought it new, but I changed to 4 rib when they wore out. The 4 rib didn't rough up the hay fields so much when turning short with the haybine or round baler.
For turning 3 will be slightly better, I use 4 ribs due more rubber longer lasting and excessive road travel. (per tire guy)
if its a loader, or fully weighted, or front hitch, or chemical tank, go 4 rib to handle the weight. If just a hay/utility/rake tractor, a 3 rib will turn better with less weight on the front, 3 rib goes away faster on the road, 4 rib is harder to follow a corn row for spraying or cultivating, especially if you have water marks.
