Deere 4219 or 4202 engine ID?
brainsboy
New User
I need to order a rebuild kit and cant figure out what motor I have. The casting number on the block R72973 comes up as a 4202, but the liners are slightly over 4" like the 4219. Engine tag says TO4219D114426. Is it possible that 4202 and 4219 liners interchange? Pins are 1.365" and seals are in bottom of block bore.
Late style 202 & 219 are same block, R72973 cast # is it both parts books, sleeves 'liners' interchange.. Your engine tag '4219D' says, 4 cyl. 219 ci. diesel ....
(quoted from post at 21:25:44 02/27/15) Late style 202 & 219 are same block, R72973 cast # is it both parts books, sleeves 'liners' interchange.. Your engine tag '4219D' says, 4 cyl. 219 ci. diesel ....
Will the head from a 4202 fit a 4219?
202 head part # AT21334 also fits a 2030 plus 34 other engine applications
