I'm just about done my diesel swap into my
2510. I ended up finding a cheap, 4.5
Powertech. I was later told thats not a
good engine for the swap, as its not a
structural block, but 2 quotes came to
mind- "A bird in the hand is worth 2 in
the bush" and "If she goes she goes, if
she blows she blows". Ill be the guinea
pig and post back if it fails. I had to
drill and recap 4 holes in the back of the
block to a larger size. Switched the tach
drive over from the gas engine. Used a
remote mount oil filter and made an
eliminator for the oil cooler as it was
into the frame rail. Used the gas fan.
Made my own thermostat housing and
radiator hoses as well as intake piping
and alternator mount. Modified the
throttle linkage. I think that's about it.
Hindsight, a 276 or 4.5 from a tractor
would have been better. My block didn't
have the balancer shafts in it and you can
feel the vibration a little bit. Although
everything is there to put them in down
the road it looks like. Maybe next winter.
My uncle found a 4045 turbo engine hes
going to swap into a 3020 he has with a
blown engine. He has the hydraulic pump
mount and adaptor plate. Just needs time
now. That'll be a fun project too.
Here's a picture from today and one from
the day I bought the tractor.
